AutoCAD Mechanical Forum
Welcome to Autodesk’s AutoCAD Mechanical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Mechanical topics.
SketchBook Designer data can only be saved in DWG file format
8 REPLIES 8
Message 1 of 9
acwtzwegers
7542 Views, 8 Replies
"SketchBook Designer data can only be saved in DWG file format and will be omitted from other file types."
Why do we get this message?
I don't care about "sketchbook" (whatever it may be), nor about "other file types"... Now... how do I make sure this message doesn't appear?
http://forums.autodesk.com/t5/AutoCAD-2012/Sketchbook-error-in-Autocad/td-p/3015524 does not answer anything except confirm that I'm not the only one annoyed by it.
8 REPLIES 8
Message 2 of 9
michaelsu
in reply to: acwtzwegers
I think this warning message comes from SketchBook Designer addin. I guess you may have installed those products from Suite installer.
So maybe you can try to uninstall the addin of SketchBook Designer for AutoCAD and see if the message goes away. see snapshot.
Thanks.
Michael Su
SQA Engineer
Please mark any response as "Accept as Solution" if it answers your question.
Message 3 of 9
Greatwhitenorth
in reply to: michaelsu
Has this issue been resolved with a hotfix/patch yet?
____________________________________________________
Product Design & Manufacturing Collection 2021 | Vault Professional 2021
Dell Precision 7670 | Intel i7-12850HX - 2100 Mhz - 64GB
nVIDIA RTX A3000 12GB | Windows 10/64 Pro
Message 4 of 9
Nevermind...  I figured out how to stop the message so copy works again.
Message 5 of 9
syahidie
how you stop it?
Message 6 of 9
michaelsu
Will uninstall SketchBook designer addin work for you?
Go to Control Panel\All Control Panel Items\Programs and Features, then find a program like SketchBook designer addin?
Thanks.
Michael Su
SQA Engineer
Message 7 of 9
trevathanjef
Unstalling the "SketchBook" at the control panel solves the error message when saving a drawing.
Message 8 of 9
bvanallen
in reply to: trevathanjef
I am getting the same error in a couple of my drawings, but do not have this "sketchbook" installed. It is not listed in my control panel/programs and features. I do have a "sketch-up" add on for Autodesk though. Would uninstalling this remove this annoying error?
Message 9 of 9
How do you resolve this issue?
”Boost
