Are there any known (or unknown) issues with using the Sheet Set Manager and AutoCAD Mechanical?
Solved by michaelsu. Go to Solution.
Sheet Set Manager in AutoCAD Mechanical should work the same as it should in AutoCAD. Have you encountered any issues at your side?
I have experienced no problems. I have a client who uses the SSM and has upgraded to AcadMechanical and wanted to know if they could continue using the SSM or not. I wanted to confirm that there wasn't a known problem. Thanks.
