AutoCAD Mechanical Forum
Welcome to Autodesk’s AutoCAD Mechanical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Mechanical topics.
Sheet Set Manager
2 REPLIES 2
dennis
467 Views, 2 Replies
Sheet Set Manager
Are there any known (or unknown) issues with using the Sheet Set Manager and AutoCAD Mechanical?
2 REPLIES 2
michaelsu
in reply to: dennis
Sheet Set Manager in AutoCAD Mechanical should work the same as it should in AutoCAD. Have you encountered any issues at your side?
Thanks.
Michael Su
SQA Engineer
Please mark any response as "Accept as Solution" if it answers your question.
dennis
in reply to: michaelsu
I have experienced no problems.  I have a client who uses the SSM and has upgraded to AcadMechanical and wanted to know if they could continue using the SSM or not.  I wanted to confirm that there wasn't a known problem.  Thanks.
”Boost
