AutoCAD Mechanical Forum
Welcome to Autodesk’s AutoCAD Mechanical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Mechanical topics.
Save as in 2005
1 REPLY 1
WilliamT
149 Views, 1 Reply
Save as in 2005
You can't open a drawing created in AcadM 2005 and open it in 2004/DX - although this isn't the case with Vanilla AutoCAD. When I save in 2005, the file type defaults to an AcadM 2005 drawing and I can obviously chang ethe filetype to save back to 2004DX, Machanical 6, etc.
My query is this: When I access the open and save options, I can set the system to default to 2004DX on each save. However, when I save as, it still defaults to 2005. Annoyingly, It works as you'd expect if you set the default to 2000. It's not a huge problem but it's a little tedious having to chang ethe file type each time I save.
Thanks in anticipation.
William
1 REPLY 1
in reply to: WilliamT
You can use the un-documented instruction AMSAVEASACADM2004DX, in order to store data in the 2004DX format.
sincerely
ecco
”Boost
