AutoCAD Mechanical Forum
Welcome to Autodesk’s AutoCAD Mechanical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Mechanical topics.
Read Only Files
2 REPLIES 2
302 Views, 2 Replies
Read Only Files
I have version 2013, I just upgraded not long ago and every single time I open a file it gives me a warning dialogue box that says this file is read only or in use do you still want to open it. It is driving me nuts!!! I know I can go in and change the settings and change that, but every single time? Is there no way to "undo" something in my settings to make that permanent?
2 REPLIES 2
michaelsu
Will this link below give any help on the problem?
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=2865666&linkID=9240617
Thanks.
Michael Su
SQA Engineer
Please mark any response as "Accept as Solution" if it answers your question.
tlebrun
We just started using 2013 today, and ran into this problem.
Is ther a way to manually delte the lock files? (.dwl)
”Boost
