AutoCAD Mechanical General Discussion
Active Member
SamRol
Message 1 of 4 (167 Views)
Problem with shader on curved surfaces - Installation Drawing - Mechanical 2011
167 Views, 3 Replies
08-28-2012 02:53 AM
Hi everybody,
   as you can see in the attached image, in some surfaces apperas the "triangles" of the surface and in others not. Please, do you know any command or variable which could resolve this?? I would like to have all the surfaces smoth, without triangles.
Active Member
SamRol
Message 2 of 4 (132 Views)
Re: Problem with shader on curved surfaces - Installation Drawing - Mechanical 2
09-12-2012 01:16 AM in reply to: SamRol
Nobody has this problem???
Employee
michaelsu
Message 3 of 4 (130 Views)
09-12-2012 07:17 PM in reply to: SamRol
It would be helpful if you post a sample drawing for further look. Or you can send me (Email: zhiyuan.su@autodesk.com) the drawing.
Thanks.
Michael Su
SQA Engineer
Please mark any response as "Accept as Solution" if it answers your question.
Active Member
SamRol
Message 4 of 4 (127 Views)
09-13-2012 12:00 AM in reply to: michaelsu
Here is a zipped dwg to test.
Thanks in advance and kind regards
Sam
