Hello All,
we have setup a network and all employee work on network. we have domain base network.
so i have a problem with saving file. and that file save as .tmp file.
when my employee open drawing from network and save as local drive then it come that unable to save file. and file will be save as .tmp file.
if file will successfully save to local drive then after edit that drawing not saving with same error.
I have checked permission of that local drive also it has full control to that user.
So please help me out of this.
Pwn
Solved by pendean. Go to Solution.
The user must have full delete/read/write access to the folder, no restrictions: AutoCAD saves to a tmp, deletes a BAK file, renames a DWG to BAK then TMP to DWG (or some combo like that).
There is nothing to set inside AutoCAD Mech, this is a Windows/Server user rights setting.
