AutoCAD Mechanical General
Pwn
Member
Message 1 of 2 (335 Views)
Problem in saving files in Autocad Mechanical 2013
335 Views, 1 Replies
11-09-2012 10:10 PM
Hello All,
we have setup a network and all employee work on network. we have domain base network.
so i have a problem with saving file. and that file save as .tmp file.
when my employee open drawing from network and save as local drive then it come that unable to save file. and file will be save as .tmp file.
if file will successfully save to local drive then after edit that drawing not saving with same error.
I have checked permission of that local drive also it has full control to that user.
So please help me out of this.
Pwn
pendean
Message 2 of 2 (323 Views)
Re: Problem in saving files in Autocad Mechanical 2013
11-10-2012 07:36 AM in reply to: Pwn
The user must have full delete/read/write access to the folder, no restrictions: AutoCAD saves to a tmp, deletes a BAK file, renames a DWG to BAK then TMP to DWG (or some combo like that).
There is nothing to set inside AutoCAD Mech, this is a Windows/Server user rights setting.
Dean Saadallah Blog | Facebook | Google+ | Twitter | PINS
You are not logged in.
Ask the Community
