Please I need help ASAP! I am using PVC fitting blocks which I am inserting through Tool Palettes and they have Part References embedding in them. Every so often after finishing an assembly, saving and printing (every thing is fine)... the next time its opened some of the reference nodes, balloons and parts list entry will be missing! My most recent example has 2 specific parts missing from the entire assembly while the rest were just fine.
What could be the cause of this? I have my suspicions that it is only happening on drawings opened and saved by a coworker who uses Vanilla AutoCAD 2010, but I am not positive.
Thank you in advance for your prompt responses!
AutoCAD Mechanical 2010
Brian
Hi Brian,
Are those entities in a drawing being xref? If save mechanical drawings in AutoCAD format, those mechanical entities like part references, balloons will become blocks but not disappeared.
So for further look, can you please send a problem drawing and a correct drawing to my email zhiyuan.su@autodesk?
If your co-worker is actually using new AutoCAD methods instead of pre-1992 ones, it may be related to that: there are several newer (versions of) commands (also, ironically, within AutoCAD Mechanical) that make partrefs and such disappear, or treat them like "custom objects" to be removed.
I also came across the matter that in some configs of "vanilla" AutoCAD, you can't actually see the partrefs very well - or at all (based on node/point sizes).
This can cause accidental removal (together with the fact that they may not stick to their assigned objects anymore).
Check first if your co-worker has his "proxy graphics" enabled - but preferably make sure he/she/them starts using Acad Mechanical as well: you can mod it to work/look like vanilla w/o it removing your objects.
Hi
Can you check the file version set in options dialog box?
Options>>Open and Save Tab>>Save As dropdown>>The file version should be "AutoCAD mechanical 2015 drawing". If you see any of AutoCAD 2013 or other AutoCAD formats, the drawing is saved in vanilla AutoCAD format and all mechanical intelligence is lost.
Thanks Sridhar, that solved my problem!
BTW, could we suggest that ACAD Mech to alert users that those intelligent data will get lost when the file is saved as ACAD vanilla version?
Sincerely,
Don
Don,
Glad to know the issue is resolved.
I will log a wish list to have this alert considered for future releases.
Thank you for solving that issue.
I've got another question: is there any chance to restore those blocks into parts again? My company policy is to save all the files as AutoCAD2004 as a default. I've got files with blocks instead of parts now and my week worth work is gone...
That would save me tons of work 🙂
Thanks!
Hi
If the drawing contains standard parts and symbols, we may need to reinsert them again. if they are blocks with part references, you may need to re insert part references for respective blocks.
If your requirement is save to 2014 format, you may choose "AutoCAD Mechanical 2014" file format from Save As>>type drop down dialog box.
Sridhar
