AutoCAD Mechanical Forum
Welcome to Autodesk’s AutoCAD Mechanical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Mechanical topics.
Parameterized Text With Frame Around
0 REPLIES 0
Message 1 of 1
brunobiazotti
268 Views, 0 Replies
Hi.
I need build a text with frame around parameterized, the increase of the frame happens when we write in block parameterized with Enhanced Attribute Editor. More characters, the greater will be the frame.
But i can't, because, I do not know anything that measures the size of the text (characters) and put as relation to the variation in linear stretch parameter of the frame. (attached). I tried with unsucess use the Field command.
Regard.
0 REPLIES 0
”Boost
