Hi.
I need build a text with frame around parameterized, the increase of the frame happens when we write in block parameterized with Enhanced Attribute Editor. More characters, the greater will be the frame.
But i can't, because, I do not know anything that measures the size of the text (characters) and put as relation to the variation in linear stretch parameter of the frame. (attached). I tried with unsucess use the Field command.
Regard.
