AutoCAD Mechanical Forum
Welcome to Autodesk’s AutoCAD Mechanical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Mechanical topics.
Orientation of object changes when using xref "copy to working set"
3 REPLIES 3
jpblower
299 Views, 3 Replies
For some reason when I use copy to working set while editing an xref the orientation of the object goes haywire.  When I add the object, no problems.  I have to repeat this process roughly 400 times.  I either have to have an object copied 400x to add to each reference over and over again or I have to align each object after I add it to the xref.  It's enough of a pain to have to copy this to the xref but I've got a method that might speed things up which I can't use if I have to keep reorienting the objects.
I'm using ACAD Mechanical 2011.
3 REPLIES 3
Can you share with us your drawing file and the exact steps to reproduce the problem. I will have a look into it as soon as i have them from you.
Vinod Balasubramanian
AutoCAD Industry Support & Escalation Lead
jpblower
in reply to: jpblower
I can't send the actual files but I'll see if I can send something representative that consistently gives me the same problems.  I thought it might be a ucs problem but I get the same results when I align and set to world.
Are you looking for something similar to the one below,
http://forums.autodesk.com/t5/AutoCAD-2000-2000i-2002-Archive/Copying-objects-to-quot-REFEDIT-quot-w...
”Boost
