AutoCAD Mechanical Forum
Welcome to Autodesk’s AutoCAD Mechanical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Mechanical topics.
Open Solidworks drawing in AutoCAD Mechanical...
4 REPLIES 4
2809 Views, 4 Replies
How can I open Solidworks drawing (.sldprt) in AutoCAD Mechanical...?
Can anyone help me with this..?
4 REPLIES 4
Sridhar-Autodesk
Hi Lucel,
You may export Solidworks drawing in STEP or ACIS format.
Import this 'neutral file format' file in AutoCAD Mechanical using stepin or acisin command.
Sridhar
Software QA Engineer
Manufacturing Solutions Division
Autodesk, Inc.
Sridhar Subramani
Senior Product Owner
Hi Sridhar,
Can you give me a step by step procedure on how to do it...
Thanks a lot!!!
Lucel
Sridhar-Autodesk
Lucel,
Have your Solidworks user export the file in Step or acis format. probably he/she might be knowing how to export the file.
Launch AutoCAD Mechanical-->Open a new dwg file-->command: stepin or acisin-->check if the import is successful.
Sridhar
Sridhar Subramani
JDMather
When your SWx operator Save As type ACIS (*.sat) make sure that Options are set to v7
or
Download free Inventor LT from http://labs.autodesk.com to open the *.sldprt and convert to dwg yourself (Applications>AEC Exchange>Save As DWG solids)
or
zip and attach the file over here and ask someone to convert it to DWG for you http://discussion.autodesk.com/forums/forum.jspa?forumID=78
”Boost
