AutoCAD Mechanical Forum
Welcome to Autodesk’s AutoCAD Mechanical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Mechanical topics.
Multiline attributes and amtitle
2 REPLIES 2
cadcamm99
311 Views, 2 Replies
Does anyone know if multiline attributes and amtitle is supported in AutoCAD Mechanical 13?
2 REPLIES 2
michaelsu
in reply to: cadcamm99
As far as I know, multiline attributes are not supported in AMTITLE if you use those "GEN-TITLE-XXX{xxx}" tags. But you can define your own multiline attributes and it should work like normal block.
Thanks.
Michael Su
SQA Engineer
Please mark any response as "Accept as Solution" if it answers your question.
cadcamm99
in reply to: michaelsu
The problem I get is that when I insert the title block using AMTITLE, I do not get the ellipse button to edit the multi-line text.  Even if I double click on the title block after inserting it I do not get the ellipse button to edit the text.
However I did find out that if I select the title block and select properties, I do get the ellipse button in properties.
”Boost
