I am trying to convert our company to use paperspace for Autocad dwgs. ran into the following issues:
1. paperspace dimensions dont update to viewport changes -unless Im missing an "update" command.
2. How can I make the Mechanical Detail command work in paperspce?
The following are some general paperspca questions:
3. Should I dimension in model space or paper space?
4. I can use the mechanical section line command in paperspace, but does anyone use the mechanical detail command?
5. Is the "LAYOUT" tab in mechanical (2013) for 3d stuff only? I cant get it to work w/2d stuff.
6. Generally speaking, does creating views in paper space a better/easier workflow? Is it more efficient?
Paperspace (Layout Tab) is typically reserved for model / drawing documentation. Within the layout you are able to crete viewports which act as a picture frame into the model space. When dimensioning in paperspace it is important to make sure that you use OSNAP and attach the dimension string to model geometry.
As far as showing actual 3D geometry within paperspace, you are unable to change the main view of the layout tab to say SE Isometric. The model geometry should reside within the model space, and a viewport be placed into paperspace so you can change the view.
Using Paperspace allows you to have the flexibility to create a single viewport or multiple viewports to show different aspects of the model space. Once the viewport is created, you can change its size, properties, scale, and position as needed. You are also able to specify which layers are visible in each viewport.
- We need several different versions of the same drawing (one for the customer, one for production (less dims) etc). We place all texts in the drawing properties and all objects in Model. The objects can all be the same in all tabs, the texts are as well (using fields) and we only need to enter both of them once. The differences between versions are placed on the tabs. (in our case we copy the customer tab to a production tab and generally just delete dims).
- If you combine scale areas with parametrics for fabrication drawings you can make 1:1 drawings of objects in Model, link scale areas to important bits and use parametric variables to quickly generate all different types of lengths of the same product: change "length", refresh the viewports in paperspace and your new drawing is ready. The only dodgy bit here is that you then need to dimension in Model because you cannot dimension between two viewports.
