When locating the first point of a line or the center of a circle, my curser point does not follow the mouse movement smoothly. There is a slight delay between the mouse and point that sometimes makes it difficult to lock in on the correct position. I am not an every day user of AutoCad and this seams to be a condition that has just happened recently. Thanks for any help you can give.
Chris
Hi Chris,
Can you try turn off Dynamic input by F12 key or set sysvar ROLLOVERTIPS to 0? Is it getting better?
Also, it's always recommended you use certified graphic cards with the latest driver. To verify what driver you should be using use the 3DCONFIG command. The View Tune log will indicate what version is installed. Verify if this is the recommended one at:
http://usa.autodesk.com/adsk/servlet/syscert?id=18844534&siteID=123112
While you're in 3DCONFIG go to Manual Tune and make sure that 'Enable hardware acceleration' is selected.
