I have been experiencing some issues on the brand new ACADM 2015 when trying to use some commands:
- Scale area - amscalea
Consider drawing a rectangle by the command amscalea and define a scale 1:1. After that make a profile and use the aminertia command to place the result table beside the profile. Now try to change the scale area to another value by double clicking the scale area. What I see here is that the scale affects only the axis numbers and nothing more, when closing command I get a exception in VEVAL-STR + ARX command and the message "Unhandled Exception E06D7363 (e06d7363h) at adress FD3B940Dh"
- Trying to perform a rescale on the data generated by the deflection line command (AMDEFLINE) is also incomplete, with only some of the texts being rescaled.
- Double clicking the table generated by the command AMDEFLINE asks as for a table generated by the command AMINERTIA, this is normal. But when I try to complete the command ACADM gives me message "Insufficient support" even if it is ok. See my example, every support is there, in fact it worked when I first generated the table of deflections. But it is impossible to reedit.
Can you please try the suggestions in the following for the unhandled exception,
For the other issue, I will take a look at the drawing and get back to you soon.
thanks Vinod Balasubramanian,
I will be waiting for a correction, I think the workaround is enough for a while, at least for some casual usage.
Thanks Dimtri for the confirmation. I will inform the development team of your concerns and will request them to priortize for an early fix and will post the fix once available for you to download.
still no solution, eh? just a work around? they must have picked up some advice from our IT folks here. Better a work around that requires someone else to do more work than me bothering to fix something.
this is frustrating. I have to repeatedly go through the entire deflection line process every time I reviese whatever it is I am working on. maybe I'll go back to paper or just use excel and live with the lack of clarity I get from the drawing.
We swapped the lisp files as detail in
it made no difference. Did this work for others?
