Has any one have problems when you MESH four sides with one having a 2 inch arc radius, to where it does not fill the full 2 inch radius?? The radius on the MESH does not follow the 2 inch radius contour. The MESH radius is drawn short by about 20% of the full 2 inch arc radius. Thanks.
Attached are a PDF plot of the Mesh not extending out to the contour line, and the test drawing with new information. Drawing shows three orange arrows where the blue mesh does not connect to the 2" radius. The question is there a setting or to change the mesh resolution so it will fill into the radius?? Thank You.
Thanks for your question.
If you try to set the two variables SURFTAB1 and SURFTAB2 both to a value bigger than 6 (I have tried with 20) and recreate the mesh, you should be able to see a better approximation to your profiles. Try and let me know if it works for you.
In attachment the mesh with surftab set on 20
