I've been drawing in wireframe with some simple solid modeling off and on since release 12. Mechanical 2011 was ok. Mechanical 2012 has changed something. I can't move things and pick points and get them to go where I intend. I turned off the z axis but that hasn't helped. I can't draw lines or move things much of the time.
Is there any way to make 2012 behave like earlier releases when doing 3d wireframe and solids?
Have you got your problem resolved?
If not, can I have a look at your sample drawing first? Please send your sample drawing to zhiyuan.su@autodesk.com. Or you can post some snapshots showing the differences and what you want so it would be easier to understand the problem and provide some workaround.
