AutoCAD Mechanical General
Active Contributor
suresh_070379
Message 1 of 2 (336 Views)
Match property for layer manager
336 Views, 1 Replies
11-19-2013 08:34 PM
We are having two set of ACAD drawings. One is drawn in Autocad itself from scratch and another is converted from solid works. In our company, we are using hundreds of layer. In the Autocad based drawing, we have lay off/ freeze lot of layers based upon the particular requirement. i want these same layers to be on/off in the solidworks converted drawing. if i go manully and change one by one, it is taking lot of time. Kindly suggest, is it possible to match the properties of layer manager from one drawing to another.
Suresh
Active Contributor
suresh_070379
Message 2 of 2 (315 Views)
Re: Match property for layer manager
11-21-2013 04:22 AM in reply to: suresh_070379
i have found out the answer.
Layer states manager=>import from other drawing=>restore.
Suresh
You are not logged in.
Ask the Community
