I have AutoCad Mechanical 2010. It was crashing occasionally (probably my graphics card). When autocad crashes, it wants you to send the info to autodesk. I did that and it said there was a patch for my problem. After the patch installation, I do not have any mechanical commands. I did the demandload without success. I need specific instruction on what to do. Don't just say open CUI because I don't know how that works. Please help.csmith@fusion-etc.com 920 664-1542 Carol A. Smith
Have you tried to "initialise" Autocad profil ?
Close your Autocad application
You need to open the regedit command into windows - start menu - run
Go to the HKEY_CURRENT_USER\Software\Autodesk\Autocad and delete the R1X Directory. For example, I've Autocad 2010. I need to delete the R18.0 Directory.
Start Autocad again.
Control panel >> programs and future >> click AutoCad Mechananical >> Chose repair >> restart autocad >>goodluck !
