I am finding it very difficult to work with leaders. I use the dimension style manager to modify the text color of dimensions, and leaders remain yellow - an unreadable color against a white printed background. The text color of other types of dimensions does change, but not leaders. What gives?
I am starting to realize my problems run much deeper than just leader text color.
My problems, among others...
Every time I touch text and dimension styles in Autocad I get completely stumped. They appear to behave in a complete inscrutable way. Objects in the drawing sometimes update when I change the style, and sometimes not. I can never tell when something will work. How can something so fundamental to CAD be so broken in this software for so long?
You must be very careful which dimensions you are using. There are two in Mechanical: Vanilla dimensioning tools and the Power Dimension tools. To change the appearance of the Mechanical content, you will need to access the AM:Preference tab in OPTIONS. Right click and you should get a dialog which allows you to designate colors for Mechanical content such as balloons. Certain Mechanical layers are also assigned colors by AutoCAD which override your colors in your dimension style. There is a chart of these layers in the Mechanical content which you may have to alter to suite your needs.
