AutoCAD Mechanical Forum
Welcome to Autodesk’s AutoCAD Mechanical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Mechanical topics.
Is this layer bug in autocad mechanical 2012??
2 REPLIES 2
sbcho
463 Views, 2 Replies
hello~
i'm korean autocad user.
i have some question about autocad mechanical 2012.
1. copy command is OK~ block layer color is not changed
2.i use copybase command (ctrl+shift+c) when i copy the block.
but  block layer color is changed to white when i copy.
anyone know about the this situation??
ateachments *.dwg file and *.jpg file
2 REPLIES 2
michaelsu
in reply to: sbcho
I tried your dwg and COPYBASE to select the objects and paste it, but I didn't see the color changed. I am using AutoCAD Mechanical 2012 SP2.
What about reset Settings to default from start menu->Autodesk->AutoCAD Mechanical 2012? Can you still reproduce this issue?
Thanks.
Michael Su
SQA Engineer
Please mark any response as "Accept as Solution" if it answers your question.
sbcho
in reply to: michaelsu
hello~
I reinstalled Autocad mechanical 2012 and update service pack 1 and 2
ctrl+c and paste ...only " 0" layer is changed the white
my windows system is 64bit
but 32bit system is no problem.
my english is not good
if you send me your e-mail, i'll send you video about this problem
my email is bomige@naver.com
thank you your reply
”Boost
