Thank you for using AutoCAD Mechanical.
This is the current behavior of Inventor Companion. The steps were
documented in the help file. Key in "Section View" at help find to list the
following:
"Draw a cut line in the parent view. The first line segment of the cut line
must start outside the part or assembly and end inside the part or assembly.
The second line segment must start inside the part or assembly and end
outside. Only two line segments are allowed when creating a cut line for an
aligned section view. "
We would like to thank you for using Inventor Companion and please do not
hesitate to forward us any question you might come across while using the
product.
kim-chwee.ang@autodesk.com
Product Designer
Manufacturing Solutions Division
Autodesk, Inc.
"bumsquish" wrote in message
news:21698996.1095856177449.JavaMail.jive@jiveforum2.autodesk.com...
> I created an Inventor companion file and I need to create a section to
this part. The section requires more than two section lines. When I
attempt to create the aligned section, it tells me it must contain exactly 2
segments. I have 4 segment lines and it won't let me section it. I
converted them all to one polyline. Is there anything I may be able to do?
This is my first attempt at creating a companion file and i can use all the
help I can get.
> Thanks.
> Jeff
