Hi all
I am trying to create a template, but need the template to have a costum drawing in. I create the drawing but once I save it as a template ("save copy as template") it does not save my drawing. I cannot place it in the definition as I do not want all the sheets to have the drawing on, only the one sheet. Also how do I place a first angle projection sign in the left bottom corner of the drawing? I have drawn my own, but have the same problem as above with it. As a drawing it does not save to the template and in the defintion - if I change the sheet size for only that specific sheet the sign sits in the middle of the sheet.
Looking forward to your response.
You may have better luck getting an answer in the proper forum, here - http://forums.autodesk.com/t5/Autodesk-Inventor/bd-p/78
Thank you Steve, my apologies did not see I was in wrong forum.
Have a fantastic day!
