Please help if you can, I've rebuilt my installers to not include any updates (which is a pain) and I've completely uninstalled all parts of both programs.
What gives?
=== Verbose logging started: 7/22/2013 16:58:52 Build type: SHIP UNICODE 5.00.7601.00 Calling process: C:\Users\rtunderw\AppData\Local\Temp\_AICCF0.tmp\Setup.exe ===
SetAcadInstallDir
Action start 16:59:13: SetAcadInstallDir.
CustomAction SetAcadInstallDir returned actual error code 1603 (note this may not be 100% accurate if translation happened inside sandbox)
MSI (s) (5C:C4) [16:59:13:663]: Note: 1: 1708
MSI (s) (5C:C4) [16:59:13:663]: Product: AutoCAD Mechanical 2013 - English -- Installation operation failed.
MSI (s) (5C:C4) [16:59:13:663]: Windows Installer installed the product. Product Name: AutoCAD Mechanical 2013 - English. Product Version: 17.0.48.0. Product Language: 1033. Manufacturer: Autodesk. Installation success or error status: 1603.
MSI (s) (5C:C4) [16:59:13:663]: Attempting to delete file C:\windows\Installer\34195f5b.mst
MSI (s) (5C:C4) [16:59:13:663]: Attempting to delete file C:\windows\Installer\34195f5c.mst
MSI (s) (5C:C4) [16:59:13:679]: Deferring clean up of packages/files, if any exist
MSI (s) (5C:C4) [16:59:13:679]: Attempting to delete file C:\windows\Installer\34195f5b.mst
MSI (s) (5C:C4) [16:59:13:679]: Unable to delete the file outside of the engine. LastError = 2
MSI (s) (5C:C4) [16:59:13:679]: Attempting to delete file C:\windows\Installer\34195f5c.mst
MSI (s) (5C:C4) [16:59:13:679]: MainEngineThread is returning 1603
MSI (s) (5C:10) [16:59:13:679]: RESTART MANAGER: Session closed.
MSI (s) (5C:10) [16:59:13:679]: No System Restore sequence number for this installation.
=== Logging stopped: 7/22/2013 16:59:13 ===
MSI (s) (5C:10) [16:59:13:679]: User policy value 'DisableRollback' is 0
MSI (s) (5C:10) [16:59:13:679]: Machine policy value 'DisableRollback' is 0
MSI (s) (5C:10) [16:59:13:679]: Incrementing counter to disable shutdown. Counter after increment: 0
MSI (s) (5C:10) [16:59:13:679]: Note: 1: 1402 2: HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Installer\Rollback\Scripts 3: 2
MSI (s) (5C:10) [16:59:13:679]: Note: 1: 1402 2: HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Installer\InProgress 3: 2
MSI (s) (5C:10) [16:59:13:679]: Decrementing counter to disable shutdown. If counter >= 0, shutdown will be denied. Counter after decrement: -1
MSI (s) (5C:10) [16:59:13:679]: Restoring environment variables
MSI (s) (5C:10) [16:59:13:679]: Destroying RemoteAPI object.
MSI (s) (5C:1C) [16:59:13:679]: Custom Action Manager thread ending.
MSI (c) (18:E0) [16:59:13:695]: Decrementing counter to disable shutdown. If counter >= 0, shutdown will be denied. Counter after decrement: 2
MSI (c) (18:E0) [16:59:13:695]: MainEngineThread is returning 1603
=== Verbose logging stopped: 7/22/2013 16:59:13 ===
I believe this is the issue.
If you have any AutoCAD 2013 SP or Sync Update, it will also block the install.
Hello, I'm trying to install the same suite and get THIS error message. When this pops up, the installer closes.
Suggestions?
---Steve
