AutoCAD Mechanical General
Message 1 of 4 (139 Views)
Insatlled AutoCAD Mech 2013, now I have no printers
139 Views, 3 Replies
04-30-2012 12:12 PM
Installed 2013 mechanical and now I have no printers at all. Not even the ability to pdf. IT has no solutions. any help would be appreciated.
Employee
Message 2 of 4 (121 Views)
Re: Insatlled AutoCAD Mech 2013, now I have no printers
05-01-2012 08:06 PM in reply to: chemlite91
Can you please let me know the detail on how you install the product and also your machine detail?
You should be able to find plotters after run PLOTTERMANAGER command. It will open the plotters available.
My machine is win7 64bit and default plotters are as below.
C:\Users\xxx\AppData\Roaming\Autodesk\AutoCAD Mechanical 2013 - English\R19.0\enu\Plotters
I have zipped the plot styles for reference.So you can use Add-A-Plotter Wizard to add plotters.
Thanks.
Michael Su
SQA Engineer
Please mark any response as "Accept as Solution" if it answers your question.
Message 3 of 4 (110 Views)
05-04-2012 06:16 AM in reply to: michaelsu
Thanks for the help. after not being able to print for the past week, we repaired the software and that didn't work. it finally took re-installing 2013 two times for it to install correctly. i'm unsure what happened during the install, but at least in the end it fixed itself.
once again thank you.
Diana
Employee
Message 4 of 4 (103 Views)
05-07-2012 08:11 PM in reply to: chemlite91
You are welcome.
Glad your issue is resolved. :smileyhappy:
Thanks.
Michael Su
SQA Engineer
You are not logged in.
Ask the Community
