I was trying to set the text + dim line into vertical position, but no matter how I try I can't seem to make it happen.
How should I do it? I have attach a jpg. for easier visualization.
Solved by VinodBalasubramanian. Go to Solution.
Check the link below from the help documentation. This might help you to fix this issue.
Hope it helps. let me know, if you need more help.
