AutoCAD Mechanical Forum
Welcome to Autodesk’s AutoCAD Mechanical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Mechanical topics.
How to set dimtext vertical in MDT 2012
1 REPLY 1
373 Views, 1 Reply
I was trying to set the text + dim line into vertical position, but no matter how I try I can't seem to make it happen.
How should I do it? I have attach a jpg. for easier visualization.
1 REPLY 1
VinodBalasubramanian
Check the link below from the help documentation. This might help you to fix this issue.
http://docs.autodesk.com/ACD/2010/ENU/AutoCAD%202010%20User%20Documentation/index.html?url=WS1a91938...
Hope it helps. let me know, if you need more help.
Vinod Balasubramanian
AutoCAD Industry Support & Escalation Lead
”Boost
