Dear All,
Anyone here can teach me how to change the initial value for "DI" command diaplayment?
It's 0.00 now, may I change it so that I could see more digit, e.g. 0.0000?
Thank You So Much.
If you need to see a larger value in the 'command' line I use the 'format' 'units' and change the precision. If you need to change the dimension value use 'format' 'dimension style' 'modify' go to 'primary units' tab and change the precision there.
