AutoCAD Mechanical Forum
Welcome to Autodesk’s AutoCAD Mechanical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Mechanical topics.
How to set DISTANCE initial value from 0.00 to 0.0000
1 REPLY 1
567 Views, 1 Reply
Dear All,
Anyone here can teach me how to change the initial value for "DI" command diaplayment?
It's 0.00 now, may I change it so that I could see more digit, e.g. 0.0000?
Thank You So Much.
1 REPLY 1
ut2897h
If you need to see a larger value in the 'command' line I use the 'format' 'units' and change the precision. If you need to change the dimension value use 'format' 'dimension style' 'modify' go to 'primary units' tab and change the precision there.
”Boost
