Is there a reason why I can´t seem to hatch a boundary that is on a AM_4 layer or any AM layer for that matter.
When I pick a point inside a boundary even if it is drawn as a rectangle autocad mechanical just prompts "Valid boundary not found". When I change the layer to non AM_layer the command works fine...
Anyone?
Solved by michaelsu. Go to Solution.
Valid boundaries are contours and islands on contour layers. By default, the contour layers are AM_0, AM_1 and AM_2. You can define up to four contour layers in the Object Property Settings dialog (Options dialog ->AM: Standards tab ->Double click standard node->Settings button)
In Object Property Settings dialog, please select Drafting in Category list, then customize the contours layers.
Thanks.
Michael
SQA Engineer
When I try to hatch boundary created with _spline even on AM_0 layer I get message in command line: Contour does not enclose selected point. Is it possible to hatch it?
