Does anyone know how to turn off or disable the UCS symbol when it appears when you use grips to select object or items?
Have you checked the solution below,
Is this what you are looking for.
Hi Thanks,
The post talked about the View Cube area. This is not the problem I'm having. A seperate UCS icon appears when I use grips to select something. The ICON appear, exactly where i select.
Thanks again for your help
