AutoCAD Mechanical Forum
Welcome to Autodesk’s AutoCAD Mechanical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Mechanical topics.
Find text inside dimension and amnote
1 REPLY 1
suresh_070379
487 Views, 1 Reply
if i use FIND command, it is not active on the values inside the dimensions and AMNOTE texts.
To enable this, is there any  system setting are avaiable or any other command is available.
For example, lenth of the shaft is 1500mm and if that dimension is available on the particular drawing,
if i type FIND command and type 1500, it is not showing the particular dimension.
kindly provide the solution.
Suresh
1 REPLY 1
I'm replying to your post because I can't believe AutoCAD would over look the ability to find text inside AMNOTEs.  Not having this ability leaves me to use multileaders because of the need to modify multiple notes with the same text.
Also, the ability to move the leader attachment point independently of the text is also a downside.
”Boost
