AutoCAD Mechanical Forum
Welcome to Autodesk’s AutoCAD Mechanical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Mechanical topics.
FATAL ERROR: Unhandled Access Violation Reading 0x0008 Exception at ec1c0d06h
1 REPLY 1
jpere010
1696 Views, 1 Reply
I can't find an reference to the source of this error. I did find some similar error messages stating that it requires a re-install of autocad, however nothing relating to this one exactly. I can open other dwg's fine, but on this one file both the .dwg and the .bak files are corrupted. Any ideas Autodesk?
I am using Autocad Mechanical 2012
Tags (3)
1 REPLY 1
michaelsu
in reply to: jpere010
Have you updated service pack 1 of Autocad Mechanical 2012?
Also, please also try to RECOVER the drawing to fix any errors.
If it doesn't work, could you please send me the drawing file to zhiyuan.su@autodesk.com?
Thanks.
Michael Su
SQA Engineer
Please mark any response as "Accept as Solution" if it answers your question.
”Boost
