Hello Everyone,
I have recently upgraded to Autocad 2011 Mechanical and I have noticed that when I select a line, block, or solid and I try to deselect it by hitting escape. It will not deselect the object. I did find on another thread that this has happened on Autocad 2011 MAP 3-D program and that there was a hotfix. However, I do not think that hotfix applies to Autocad 2011 Mechanical.
Is this a known issue and is there a fix for it? Thanks in advance for the time.
EDIT: I have tried the PICKFIRST command as well and it did not work either.
