I have just recently updated a hotfix and some other updates due to the fact that my CAD was running very slow and sluggish. Once they were installed it greatly improved the performance of my CAD. However, now it seems that I can no longer check in a drawing into the Vault through CAD. I have tried to see if there are any other updates for both programs yet there are none. I can however, save the drawing to, say "My Desktop" and then check it in but it will not do it from CAD. Any Ideas?
Can you tell us which version of Vault you are using?
Thank you,
On your ADMS Server, go to Control Panel>Programs and Features and find ADMS
go to the Uninstall-Repair/reinstall command and splash screen fro ADMS.
Go to Repair/Reinstall screen
Select REINSTALL
Allow ADMS to run through it's reinstall process
THere is no need to do anything further at this point.
Next open your CAD software, and try to check in your files. Also, what cad software are you using, and what file format are you checking in to Vault?
