AutoCAD Mechanical Forum
Welcome to Autodesk’s AutoCAD Mechanical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Mechanical topics.
Dimensions ignoring dimscale
4 REPLIES 4
Winks87
487 Views, 4 Replies
I was fiddling around in paperspace (trying to get our company to utilize) and now when I add dimensions to model space geometry, it is ignoring the dimscale settings.  It appears to be using a "dimstyle name $0" style override.  Is this a result of me adding dimensions to paperspace?  Did it automatically make these changes?  I want the model space dimensions back for now.  Any ideas?
Autocad Mechanical 2013
James Winkler
4 REPLIES 4
steve216586
in reply to: Winks87
The $ signifies a "child" style - that is where you have made changes that relate to only one type of dimension rather than all types of dimension. Maybe you changed something in that Dimstyle for only linear dimensions, such as annotation scale-(just an example.)
"No one can make you feel inferior without your consent. "-Eleanor Roosevelt
Winks87
in reply to: steve216586
Understand that - how would I delete this "child" style if it exists?
James Winkler
steve216586
Here's a thread with a solution: http://forums.autodesk.com/t5/Visual-LISP-AutoLISP-and-General/delete-child-dimstyle/td-p/2431674
Nicolas.Bourquin
For the problem of dimscale settings, have you already tried AMSCAREA where you can force the "text scaling" in a defined area ?
Hope that can help
Best regards
Nicolas Bourquin
”Boost
