Dear autocad community,
this is my first time asking for your help - unfortunately I couldnt find any solution by searching so far.
When I try to dimension something just nothing happens after I set up the avaible options.
I pick two points and set up the hight of the dimension line, after this a field pops up with the distance so I press enter to confirm the settings and everything just disappears.
This is in the layout section and I picked the distance between the two top edges.
After I confirm the 45 with enter or "closing editior" it just disapears.
I am using AutoCAD Mechanical 2015 64bit
edit: with the flatshot command I am able to dimension the new 2D modell, but with the 3D body its not working.
Thanks for your help
Robin
