Which release are you using? I think we have changed the workflow in the
most recent shipping version to ask you if you want to remove the definition
as well as the instance you are deleting in model space (when deleting the
last instance).
On the other hand, there is value for keeping the un-instanced definition
available from the structure catalog. For example, if you want to copy a
definition from another drawing you can place the definition and all of its
related views using the "copy definition" command into the current drawing
for use. This is nice since you may not want to add all of the views, etc.
You can also use the AMSPURGE command to remove these un-instanced
definitions as well.
How do you like mechanical structure as a whole?
Eric
wrote in message news:4869019@discussion.autodesk.com...
Ok Ok I figured it Out!!!!
I have to use the Structure Catalog to Find the Deleted Views... And Get rid
of them..
That Seems Very Redundant..
if I delete a View in the the Browser tree.. Why Does is it NOT removed from
Structure catalog???
