AutoCAD Mechanical Forum
Welcome to Autodesk’s AutoCAD Mechanical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Mechanical topics.
Custom profile not being remembered on AutoCad 2010 startup.
3 REPLIES 3
1036 Views, 3 Replies
I have a problem with AutoCad 2010. I have a custom profile that I can select and load without any problems. However, if I close AutoCad or shut down the computer to restart, it chooses the manufacture default profile on startup.
3 REPLIES 3
I had this same problem. What I finally ended up doing was setting everything up from my custom menu, making my custom profile "current". I then saved my profile as "<>" which was (in my case) the default profile that Acad 2010 kept reverting to on start-up. This seemed to remedy the situation.
Chuck - Dzine14u
Sridhar-Autodesk
You set the custom profile in the Target path as shown in the attached image.
Right click on AutoCAD Shortcut>>Properties>>Set the custom profile name as shown in the image.
Let me know if this helps.
Sridhar
Software QA Engineer
Autodesk, Inc.
Sridhar Subramani
Senior Product Owner
jmeerzo
in reply to: Sridhar-Autodesk
I have done this, but when I re-open from the shortcut it tells me that the profile name could not be found and starts up as "vanilla".  when i go to options to change the profile, the new name is there but it didn't save any of my settings. this is very frustrating. i have resorted to changing the default profile to my custom settings, but by doing this i cannot use these settings on other machines (synced from the cloud). any ideas? by the way, i'm running autocad mechanical 2014.
”Boost
