Lately when I am trying to convert a 13 page drawing to a PDF in AuotCAD 2010 it seems to take forever? It wasn't like this before? Is there a setting or something?
Solved by steve216586. Go to Solution.
Have you tried this process with with another 13 drawings to make sure it wasn't just those. I know if you are opening multiple drawings from one dwg it will PDF slower than individual dwg's.
Make sure the plot and publishing is not in the background. You can change the setting in OPTIONS Plot and Publishing mid way down on the left column.
