AutoCAD Mechanical General Discussion
Active Member
maschilke20
Message 1 of 2 (72 Views)
Creating Drawings using Inventor Model
72 Views, 1 Replies
06-25-2014 09:04 AM
Is it possible to create an AutoCAD Mechanical drawing using an Inventor Assembly file as the base view but be able to use a different Positional Representation other than Master?
Member
pereraj
Message 2 of 2 (50 Views)
Re: Creating Drawings using Inventor Model
06-29-2014 07:52 PM in reply to: maschilke20
Yes you can. You can select the positional representation from the Representation panel, from the Drawing View Creation ribbon contextual tab at the time you generate the base view (VIEWBASE COmmand). Check this link out. http://help.autodesk.com/cloudhelp/2015/ENU/AutoCAD-Core/files/GUID-D9E15363-4861-42D1-8D15-A40C7C85...
You are not logged in.
Ask the Community
