Hi
Looks like, you are clicking the copy command on the ribbon? If yes, this option invokes ampowercopy command. If you would like to have AutoCAD copy command, update the CUI.
Command: CUI>>Ribbon>>Panels>>Follow steps as shown in the attached image.
I used your fix thru the CUI with good results also. Although in older versions you could simply select the items to be copied, right click, and select "copy selection" from the quick menu.
I can not get "copy selection" when I right click anymore!
Is there a fix for this.
V Power
Once again another "improvement" from Autodesk I had to fix 20+ workstations to get all the users back to having a usable copy command. Please Autodesk don't tinker with things that aren't broke, leave functions working the way they were UNLESS you can actually improve the the function with someting that will useful to those who use the system day in day out (we are the customers after all and it used to said the customer is always right)
Hi Cadenza,
Thank you for your feedback. This wishlist was already logged and addressed in AutoCAD Mechanical 2012.
Please keep sending your feedbacks and wishlist items. We sincerely appreciate your feedback.
Please try following steps:
Command CUI>>Customize Tab>>on the left hand side, expand "Shortcut Menus">>Expand "Edit Menu">>under "command list" search for "Copy Selection">>Select the button, Drag and Drop into the Edit Menu
Find attached image for more info
Hope this helps
Glad to know the issue is resolved.
Is there any reason why this would occasionally change itself back to the older version? Every couple months I have to find this exact thread to figure out how to fix it, along with other things that seemingly randomly change to a different setting.
I cannot copy more than one object at a time in wire frame on Autocad Mechanical
