AutoCAD Mechanical Forum
Welcome to Autodesk’s AutoCAD Mechanical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Mechanical topics.
Copy & Paste suddenly quit
2 REPLIES 2
Winks87
419 Views, 2 Replies
I have an Autocad Mech 2013 user that is experiencing issues with copy & paste.  It will work for a period of time then suddenly stop.  The drawing is checked out of Vault (2013 pro) on Windows 7, Mechanical 2013.  We opened word, and did a copy & paste test there, and it still works.  It just stopped in this drawing only.  He has experienced this before and it appears to be drawing specific - he can open another drawing and it works.  It just stops in one particular drawing.  Any ideas what would cause this?
James Winkler
2 REPLIES 2
steve216586
in reply to: Winks87
Probably a corrupt file. Do an audit to see if that "fixes" anything which might effect the copy and paste command. Then maybe a recover.
If all else fails you might try creating a Wblock of the drawing objects into a clean template and to see if that fixes the problem.
"No one can make you feel inferior without your consent. "-Eleanor Roosevelt
Winks87
in reply to: steve216586
That appears to be the case (corrupt file).  This is the only dwg this happens to.  We will give this a shot.
Thanks Steve.
James Winkler
”Boost
