AutoCAD Mechanical Forum
Welcome to Autodesk’s AutoCAD Mechanical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Mechanical topics.
Convert DWG to IGES
56 REPLIES 56
Message 1 of 57
lawharrell
16486 Views, 56 Replies
Convert DWG to IGES
I have a DWG file that I need to convert to a IGES. Is there anyone that can do this for me? I do not have AutoCad nor do I know how to use it, so any help will be much help. Thanks Lonnie
56 REPLIES 56
Message 2 of 57
in reply to: lawharrell
You will need AutoCAD Mechanical at a minimum, MDT or Inventor will
generate NURBS curves which will be more accurate. Can you zip and post
the file (under 1.5MB) here?
Dennis Jeffrey, Autodesk Inventor Certified Expert
Attend the "It's a Duesy II " Manufacturing Revival Conference
March 17th, 2010 More Information at:
http://teknigroup.com
Message 3 of 57
lawharrell
Thanks for the reply Dennis. I attached the file and zipped it. I hope you can make this happen. Thank you in advance.
Lonnie
Message 4 of 57
Lonnie,
Find attached zip file containing 2 igs file. One translated using Surfaces and the other as NURBS Surfaces.
Sridhar
Sridhar Subramani
Senior Product Owner
Message 5 of 57
lawharrell
Sridhar,
Thank you for your time and effort.
Lonnie
Message 6 of 57
Capcanoe
I have a DWG file that I need converted to IGES but it is too large to post here. Could someone please help me.
Message 7 of 57
JDMather
I'm not positive but I think free Inventor Fusion will do the conversion http://labs.autodesk.com
The file size limit is much larger over here http://www.augi.com
Message 8 of 57
kedar_til
Can someone help me to convert this .DWG file to IGES? It is required for machining on VMC.
- Kedar
Message 9 of 57
sid1988
in reply to: Sridhar-Autodesk
Heyy lonnie / Shridhar
                                     Can you please convert the .dwg file to .iges please..
 I have also attached the file..
thanking you in advance
regards/siddharth
Message 10 of 57
sid1988
Heey every one ..please help to convert the below file attacted in .dwg format into .iges format.
please i am urgent need..
regards/siddharth
Message 11 of 57
dtotes
Hi I also need to convert this file to an IGES file and I do not have AutoCAD Mechanical. Could someone please help me with this? Thank you in advance foryour help.
-Dolly
Message 12 of 57
Sridhar-Autodesk
in reply to: dtotes
Find attached translated IGES file.
Sridhar Subramani
Message 13 of 57
davidsgiant
Hello! I would really appreciate if someone can convert these .dwg files to iges format. I have no possibility to do it by myself.
Thanks very much.
David
Message 14 of 57
kviusr
Thanks for sharing!
ftp server 2008
Message 15 of 57
raiderkb
I have a DWG file that I need to convert to a IGES. I downloaded Inventor Fusion but wasn't able to make it work.
Kenny
Message 16 of 57
JanKorff
Hi
Could someone please convert file below to Iges format.
Much appreciated.
Kind Regards
Jan Korff
Message 17 of 57
kirkik
Hi Dennis,
I need to convert a dwg file to igs and i don't have autodesk. Can you help me?
Kirki
Message 18 of 57
davidsgiant
in reply to: dtotes
This program is really helpful and easy to use: http://www.gidhome.com/
You can download the evaluation version for free, but geometry is limited to 25 surfaces and meshes are limited to 1000 nodes.
It worked perfectly for me.
Cheers.
Message 19 of 57
LuciaMircea
in reply to: davidsgiant
Can anyone help me to transform a .DWG file in IGES please?
I am working in Autocad 2000. A few months ago, I was able to open my drawing with Mechanical Desktop and export it as an IGES file. Why is not working any more I don't know.
Instead of pop up window asking me for the name and path for saving, now he said that IGES processing complete but I can found 2 files: one has an .xlo extension that I never heard of and one has no extension at all.
I've sent those 2 files to vacuum forming people assuming that they can do something but it is not working.
Thank you in advance for your time and help
Lucia
Message 20 of 57
JDMather
in reply to: LuciaMircea
This is a Mechanical Desktop file, not an AutoCAD Mechanical file.
Someone would need MDT and Inventor to translate.
I recommend you use the ACISOUT command and then post the results over in the Inventor forum for translation to IGES.
try the attached file.
”Boost
