You may want to look at changing the color of the "AM_CL" layer from the
default red to a color that does not dim as much. Colors such as yellow,
green, cyan and orange (color 30) are still quite visible when dimmed.
To change the color, start the "Options" dialog box and select the
"AM:Standards" tab. Within the standards list on the right hand side there
is a control for "Layer/Objects". This contains a list of all machanical
"AM" layers along with their color, linetype and other settings. Make your
color change to "AM_CL" and once applied all existing entities on the layer
will change to the selected color.
I hope this helps.
Andrew de Leon
ACADM Product Designer
Mechanical Solutions Division
Autodesk, Inc.
wrote in message news:4867352@discussion.autodesk.com...
I'm in Mech 2006..
When I activate a Component View (Top)
To Edit & Add Stuff..
Why Do Construction Lines Go Dim??
Construction Circles stay Nice & bright Red to See..
But Lines, Horiz, Vert, Angle... Get Dimmed and are hard to see??
They are Plainly Visible when NOT in an Active component View...
Just Wondering what's up with that??
