The command in progress error reared its ugly head again this morning. I was modifying a dimension (moving dimension text between lines) when it told me "command in progress...". Cannot save, escape, nothing. I did notice that when I move the mouse, it seemed to be scrolling the "command in progress" in the command line. I cannot figure out exactly what is causing this, its hard to notice until it happens. I am running Autocad Mechanical 2013 on Windows 7 with a 3dConnexion Space Explorer. I have the Space Explorer set to 2d mode while in Autocad.
Has anyone else seen this behavior? Autodesk - please help with this, this is killing my production!
Ok, I may have noticed a pattern. It appears that the unbreakable "command in progress" loop happens when fiddling around with dimensions. I was dragging dimension text when it happened the last time. Dragging dim text while autosave is happening maybe? This is happening to several users here - has anyone else had this problem?
I've had that problem sporadically ongoing since 2004Mech. CTRL/ALT/DEL Shut down and reopen. And hope you manually saved recently beforehand.
Yes, that's what I have to do. Verified something this morning: changed the text style of a dimension thru the properties box and it immediately sent up the "command in progress" error. Clicked the "x" to close the drawing (just to see if it would) and recieved a message box stating: "Lock change in progress".
Autodesk: what does this mean?
Would it be possible to provide a sample file where you are experiencing this behavior? I have attempted to test on a new file using the acad.dwt template and was unable to reproduce the behavior.
