AutoCAD Mechanical General
Distinguished Contributor lai
lai
Message 1 of 7 (294 Views)
Changing hole chart font type
294 Views, 6 Replies
11-06-2011 05:40 PM
Anyone know if there any way i can change the font type for the hole chart? Currently i am using a template whereby the hole chart is created using the BSI standard. I am looking way to change the table font style.
Product Support
Message 2 of 7 (284 Views)
Re: Changing hole chart font type
11-07-2011 07:55 PM in reply to: lai
As you said, there is no other way to change hole chart text font. You have to change text style from the standard. As you know, all the text style is controlled by the standard which the dwg is using.
Yong Jing
Product Support Specialist
Frontline Technical Support, CSS. GCSO
Employee
Message 3 of 7 (277 Views)
11-07-2011 08:05 PM in reply to: lai
In order to change the font type, you may need to create a Custom standard using following steps:
  1. Open the drawing
  2. Create a new text font type using style command.
  3. Command options>AM:smileyfrustrated:tandard tab
  4. Under “Standard” Key in any name (Custom) and press Enter key
  5. Click OK
  6. Double click Hole Chart node under standard elements
  7. From the Text Style dropdown>>Select the text style created in step-2
  8. Click OK
  9. New Hole charts created will use the new text style.
  10. For existing Hole charts>>double click Hole chart in the drawing>>Settings>>change the text font type.
Hope this helps
Sridhar Subramani
lai
Message 4 of 7 (275 Views)
11-07-2011 09:09 PM in reply to: Sridhar-Autodesk
I try before to change the text style as mention is Step 10, but just that the button is in "grey" color and can't let me to choose other fonts.
I have attach a photo and a sample of the drawing for your reference.
Employee
Message 5 of 7 (271 Views)
11-07-2011 09:25 PM in reply to: lai
Did you create a custom standard before trying Step-10?
In the attached drawing, I created a custom standard.  Now the Text Style can be changed by double clicking the holechart in the drawing.
Thank,
Sridhar Subramani
lai
Message 6 of 7 (269 Views)
11-07-2011 09:46 PM in reply to: Sridhar-Autodesk
Ok, just try again with it and it's works.Thanks for the advise...
Can i know if let said i want to delete some of my custom standard, how do i delete it?
Employee
Message 7 of 7 (266 Views)
11-07-2011 10:03 PM in reply to: lai
You may remove custom standards using AMSYMSTD command.
Please note that; if a custom standard is current/active or if any objects are inserted based on this custom standard, then we cannot remove the standard.
______________________________________________________________
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Sridhar Subramani
You are not logged in.
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Ask the Community
