AutoCAD Mechanical Forum
Welcome to Autodesk’s AutoCAD Mechanical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Mechanical topics.
Calculation of the moment of interia
1 REPLY 1
dankress
393 Views, 1 Reply
All,
I want to calculate the axial moment of inertia (X- and Y-axis directly) instead of the principal moment of inertia with AutoCAD Mechanical 2012.
Is there a way to do this with ACAD Mechanical 2012?
Thank you!
Regards
       Daniel
1 REPLY 1
gezimbasha
in reply to: dankress
If you have a figure (section profile) drawn, first use the REGION command to make it into a region, and then you could use the MASSPROP command to calculate the moments of inertia (second moments of inertia), and many more properties of a section such as area, center, bounding box, etc.
”Boost
